New rear disc swap
    New rear disc swap
    Just got finished yesterday with the swap. Got the whole swap for $100 off a 1991 accord SE. The calipers were painted a gunmetal color. I also added an oem rear sway bar to my car.
    The whole rear subframe and trailing arm setup was swapped.
    Pictures
    Click For MRT
    Now all you need is a drop
      Nice! How long did it take?
        I recently did the same swap, did you get the larger booster it makes a world of difference
        Dobermann i switched the whole rear cm for the brakes and the swaybar and i also put new springs all the way around but it took about 6hrs all together, between dropping my old rear end installing the new and the springs
        The worst part of the whole swap imo is dropping the heat shield to run the ebrake cables
        http://www.cb7tuner.com/vbb/showthread.php?t=187851
        sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
        bought from:jokerxfn-tommi-'93cb7ex
          Don't you also have to switch the proportion valve? Or is that only when the abs is deleted?
          You CAN'T Fix Stupid!
            You only really NEED that when you delete ABS
            It isnt required when doing rear discs but it would be an upgrade to add the 4040
            We didnt touch it though
              The rear disc swap took like 8 hours and the rear sway bar took like 2
              Click For MRT
                yeah that heat shield is a pain!!!
                Click For MRT
                  did you get this from a sedan or was it a coupe, not that it matters, or does it
                    I don't think it matters, but I got it from a Se Sedan
                    Click For MRT
                      very nice Swap!
                      next step Suspension
                        Originally posted by LivErN View Post
                        very nice Swap!
                        haha I know! I need to lower my car!
                        Click For MRT
                          Nice job, I'm about to drop the disks off an EX into my car, hope for it to go smooth.
                            What kinda car do you have?
                            Click For MRT
                              I have and 92 LX, I'm taking the disks off an 93 EX takin the motor to swap it too. Motors out and waiting to be cleaned up and change all seals and gaskets and belts.
