need help butterfly wheels
    Originally posted by I♥MYCb7 View Post
    true but the funny thing is o my cb i have a 89 civic and up coilover.....lolxx
    It's on the wrong suspension, and there isn't a damn thing you can do for those tires. Get the right coilovers (the cb7 is much heavier than a Civic and you're putting yourself and others in danger on those coilovers), get the alignment fixed, get a new set of tires and do it right or don't do it.
    Please go read the stickies. They'll help you learn to use the site better and save yourself from asking questions that have been answered. There's also one about attempting to use the English language correctly, it will go a long way towards helping you get better responses.
      I found this thing on youtube that will help it from doing that... just by adding washers...wish i could help but forgot what it was
        1st off this thread is in the wrong section.
        2nd: you got civic coilovers on your CB? take them off and wait til you get the money to get some that are meant for your car. like Visual said, our cars are a lot heavier than civics so the spring rates on the civic suspension is not meant to be put on an accord. and most likely your on OEM struts that are about 17-20yrs old. go buy the proper parts for your car or just stop modding it. blowing a strut on the highway will land you in an accident and if someone dies, could land you in jail.
        thats only for the rear and shouldnt even be a temporary fix.
        as for your tires, your running some bad camber AND toe if they wore down that quick. get the proper suspension for your THEN go get an alignment. mainly your toe. the toe has been proven to wear your tires out faster than camber.
          never do a temporey fix unless you in the middle of nowere. And always try to fix it right. never put civic stuff on a cb7 because we wiegh alot more.
