My Engine Bay Tuck Pics...
    hey you should do a diy on it cause im trying to do it myself
    <a href="http://www.ilovebodykits.com">Body Kits</a>
      dont do it like this then
        that wire tuck is sweet!
            dont bash the guy. if he has the skills to do this,im pretty sure he can take it apart and fix it.
            i like it. just fix the little details and your set
              Appreciate it buddy!^^^
              Originally posted by SE_DynamiK
              L M F A O !! Here's some advice: if you want to run 14's, don't sit at the light for 3 seconds after it turns green.
                I Like This Thread Theres A Lot Of Info I Can Use When I Try To Do Mines
                MY H22 SEDAN
                  id be afraid of water splashing up and damaging something ..does look hella cleaner though.. props to you
                    i like it, but im with everybody else on the placement. it worries me a little. but hey, if you can do this, then you have the skills/knowledge to fix it in the future in case anything goes wrong. good job bro
                    Soon to have the first *Bottle Fed Accord* in MI!
                    Vouch For: fatboy1185
                      Im Doing My Tuck This Weekend
                        Mock up
                        Extention and wrap
                        Safe and looks good.
                        Hell i even totaled this car with a drivers side front collision and it still ran perfect.
                        wat?
                          looks good
                            theres enough support on the web to do a wire tuck. if you search you wouldve found a better way to do things. alot of things that you did was well thought out. the thought was there but not all of. before you start tucking wires search. that the main thing you should do before you start. i read, read and looked at pics for hours before i did my wire tuck on both cars and my brake tuck on my civic. both came out great. nobody is bashing you are talking shit, they are just telling you the truth. sometimes the truth hurts and thats why people call it criticism. im not going to hate but i think it needs more help. if you think im wrong oh well
                              Originally posted by Gman86 View Post
                              Its been like that now for about 3 weeks, and weve had alot of rain here, and no issues, BUT on that note i will be Armoring/Waterprooring it now. Maybe use some large heat shrink, and a ton of heated Electrical tape.
                              keep in mind that those ridges on the top of the resistor box are actually heat sinks to keep that box cool. If you wrap it up in heat shrink or electrical tape you will hold the heat in and it'll probably melt down internally. I'd suggest moving it up somewhere behind the fender, above the wheel liner where it'll be out of the elements and not need to be weatherproofed.
                                I'm not even worried about the work. I'm curious about the location. Why are you tearing apart your engine in a sketch parking lot at night?
