need help wireing head rest tv
    i got 2 tv today and need help on how to wire them up so some 1 point me into the right way so i can get the installed
    4 door ex-l
    If there not stolen they come with instructions... But its pretty simple all you need is a video source and power.
      cool ill wire them u to my amp (+) and (-) and pick up a spare head rest and i got both 5 inch and i think i blow 1 out by trying to test it out
      4 door ex-l
        huh? like ChIoVnIdCa said, all u need is a video source, and power source. but i wouldnt say using your amp as a power source is a good idea. you can find a good power source from one of the spare openings in your fuse box. and then find a good near-by ground.
        ^^^ Please "Like" & Follow!^^^
        IG - @WerdWerx
        1990 Accord EX Coupe - Click Here
          As mentioned, grab your power source in the fuse box area. Using a fuse tap is the easiest way to get power.
          If your TVs have a remote turn on, grab that at the head unit. If not, you'll need to ensure your power source is switched.
          For video, well....the sky's the limit.
          Lexus SC300 1JZ-GTE - garage queen
          1991 Honda Accord Ex - daily beats
            thank for all the help boys but bad news i did screw up the other unite i going to see if i can get it fix or find a replacement and i have get them installed into the head rest
            4 door ex-l
              http://www.the12volt.com/installbay/...~PN~1~get~last
              help me out
              4 door ex-l
