remote start info
    remote start info
    I have done a earch and can find the right info so I was wondering,does or anyone have a user name and pass word for http://www.directechs.com/Default.aspx?ReturnUrl=%2f or something simailar I not sure if shop key will work. this can give you wiring diagrams for all cars for remote start and stereo install ex..
    i prefer http://www.the12volt.com/installbay/vehicles.html
    FA1
    355
      Originally posted by 2.2litrebeater
      i used this and it was right, but mine is 5 speed, so i pulled out the clutch switch.
      My Members Ride Thread
        yeah I always use the12volt.com, there is tons of great info on that site! Also bulldogsecurity.com has wiring info as well. I usually compare the two and check for differences just to be sure.
        -Josh
        91 Accord LX Sedan 5-speed (daily/project) - JDM H22A swap
        91 Ford Ranger XLT Supercab 5-speed 2.3L (broke)
          I checked 12volt I guess I didnt realize there was wiring diagrams there.
          Thanks for the input guys I appericate it.
          Eddie
            I have a wiring diagram for my ex, but when i put in my remote starter, i didnt even need it. It probubly would be better to use one. I just used a volt meter anp put it on the different ignition wires (i think theres ony 3, maby 4) Only took me like an hour. If you cant find the honda dealer manual, its got all the wiring diagrams.
              i have logins to directtechs and audiovox tech. direct techs changed the format of their site though to limit abuse.
              i cant give you my logins but ill get the diagrams. and using a multimeter to find the wires in a honda is eaaaaasy. especially if it is remote start only.
              Audio/Mobile Video
              WIRE COLOR POLARITY LOCATION
              Battery WHITE/YELLOW (+) RADIO HARNESS
              Accesory YELLOW/RED (+) RADIO HARNESS
              Ground BLACK (-) RADIO HARNESS
              Illumination RED/BLACK (+) RADIO HARNESS
              Power Antenna YELLOW/WHITE (+) RADIO HARNESS
              LF Speaker (+) BLUE/GREEN
              LF Speaker (-) GRAY/BLACK
              RF Speaker (+) RED/GREEN
              RF Speaker (-) BROWN/BLACK
              LR Speaker (+) GRAY/WHITE
              LR Speaker (-) BLUE/YELLOW
              RR Speaker (+) RED/YELLOW
              RR Speaker (-) BROWN/WHITE
              Amp Location IF BOSE AT EACH SPK
              Radio Security YES
              Security
              Battery WHITE (+) IGNITION SWITCH HARNESS
              Ignition 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
              Starter 1 WHITE (+) IGNITION SWITCH HARNESS
              All Door Trigger BLACK/WHITE (-) ABOVE HOOD RELEASE "BRN PLUG"
              Trunk Trigger GREEN/BLACK (-) ABOVE HOOD RELEASE "GRN PLUG"
              Hood Trigger N/A
              Alarm Disarm N/A
              Parking Lights RED/BLACK (+) AT FUSEBOX IN DRIVER'S KICK
              Convenience
              Headlights-Lo BLUE/RED (-) AT LIGHT SWITCH
              Wipers-Lo BLUE (-) LEFT OF COLUMN "BRN PLUG"
              Trnk Release ORANGE/SLV DOTS (+) IN HARNESS DRIVER FRONT DOORSTEP
              Remote Start
              Ignition 2 WHITE/BLACK (+) IGNITION SWITCH HARNESS
              Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
              Anti-Theft Descript NONE
              Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
              Neutral Safety GREEN/WHITE (-) 12 PIN CONN GEAR SELECT SWITCH
              Tachometer BLUE (-) AT DISTRIBUTOR
              Speed Sense ORANGE (AC) LEFT FENDER GRAY 6 PIN PLUG
              Brake Lights GREEN/WHITE (+) AT BRAKE SWITCH
              Reverse Lights GREEN/BLACK (+) 12 PIN CONN GEAR SELECT SWITCH
              Horn LIGHT GREEN/BLUE (-) AT STEERING COLUMN
              Modules
              WIRE LOCATION
              Please select another category
              Doorlocks/Windows
              Power Unlock BLACK/RED (-) NEGATIVE TRIGGER
              CAN BE FOUND IN A GRAY PLUG WITH BLUE TAPE AROUND IT IN SOME VEHICLES.
              PowerLock BLACK/WHITE (-) UNDER THE CARPET BELOW FUSE 2 PIN PLUG
              LF Window Up LF:RED/BLUE
              RF Window Up RF:BLUE/YELLOW
              LR Window Up LF:RED/YELLOW
              RR Window Up RR:YELLOW/GREEN
              theres alarm/remote start/keyless/audio wiring for a cb
              Member Ride Facebook
              XBOX LIVE = RedDragonsFool
              SOLD MY CB JUNE 16, 2009
              For Sale Thread
