rear speaker question?
    okay i have a 92 dx coupe and i'm wanting to install speakers in the rear. i'm aware that i'm going to need to cut the deck, anyone have any suggestions is to what i should use to cut it?
    also how do i wire them up, there are no pigtails or any such of wiring on the inside of the tunk?
    anyone?
    I would look for some speaker housings you could mount on top of the deck first, and go with some shallow depth speakers. If you just have to cut the deck, I'd go with an angle grinder. Be careful where you cut, I ported the rear deck on my Corolla several years ago and cut halfway through one of the trunk lid tension rods.
    As far as wiring, start pulling trim and run yourself some wires to the rear deck.
      okay for wiring, am i running the wire through the head unit? or the front speakers?
        are you installing a radio with amps?? or just a radio??
        if you are running a radio only, install the rear speakers wires to the rear speaker output wire on the radio it self. Since you dont have any wire pigtails in the rear deck, you have to run them all the way up to behind the radio.
        sold to: bootlegcb7, jhondayaaj
        bought from : b3nsonx , *JDM_CB7*, bmxicansd, konig52r,
        Slick_Nine, CB7_213
          why do you have to cut the deck
          1991 Cappuccino Brown LX Coupe
          2013 Rallye Red Civic EX Coupe
            i think the DX didn't come with rear deck speakers, so there are no cutouts for the speaker to sit on.
            Slick_Nine, CB7_213
              correct... The dx I have seen have been wired for them though. Id also suggest you buy oem pods for a more finished/ factory look
