Which should I do?
    Which should I do?
    I have a minor dilemma. I'm preparing to install some high end audio equipment from my last vehicle, and I'm not sure what to do for rear stage power. To clarify:
    I currently have an Eclipse AV8132 DVD head unit, along with MB Quart QM332.02CX 3-way components and an Image Dynamics IDMAX 12 v.2 D4 sub, and I'm planning on a set of MB Quart 6x9's for the rear deck. So far for power I have a Rockford Punch 400s for the fronts and an AX BD1000P for the sub. Here's where my dilemma comes in. I still have an old Punch 125.2 hanging around that needs to be repaired. (Blown output stage.) Should I send it in for repair, or pick up a newer amp to replace it? Opinions?
    ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
    Project Deerslayer
    UPDATE: DEER - 2, CB7 - 0
    '93 EX 5-speed coupe
    Short ram intake
    Tenrai Himoto catback
    Smashed front end
    I've always been a fan of rockford... espically their older punch line, i had two punch subs and i wish i didn't get rid of them... i'd say repair it
      probly cheaper to repair the amp than to buy a new one.
      -1992 Accord EX H22 234whp 185wtq
      -1993 Accord EX SOLD
      -1995 Accord EX Wagon Daily Driver
      -2012 GMC Canyon V8 4x4
        Depends on how messup it is. Get them to quote you on how much it will cost and then see if it would be cheaper to get a new amp.
        Originally posted by Maple50175
        Oh here we go again. Maples other half.
          Rockford's good...but I've always liked Alpine...
            maybe you should shop around to see what it would be to repair your amp
            ..if you think its a good price then do that
            or you could jus put it for sell or trade on here or something..
            keepin it sohc!!!
              Call Rockford customer service and find out the flat rate repair on that amp. If you are looking at a replacement amp, find out what voltage the RF amp was rated at. The older RF amps were rated at a much lower voltage than most of today's amps. And when looking at amps, do not just look at wattage output. You want to look at RMS output not max output. Also how the company tested for the RMS output. At what voltage that it is rated, at what frequency that it is rated(stay away from companies that teat at 1k tone. You are not going to listen to test tones. You are going to listen to music which s 20hz to 20k hz). There are a lot of other specs that will tell you how the amp is ging to sound. Example....slew rate...... you want a high slew rate. this will sow the ability of the amp to control the speaker. Zapco amps typically have a very high slew rate. This is why you see them in a lot of winning cars at IASCA finals. I hope this helps.
