...Well I got hooked up on a new system and I'm trying to put it in myself. I got a Sony Xplod amp (which might suck but its better then nothing) and its a 4/3 channel amp i think. I'm having a hard time hooking up the amp to the subs for the subs to turn on. I can get power to the amp because the power light is on but the subs just aren't turning on. Any suggestions?
Some difficulties..
aftermarket head unit or are you using the high level inputs from the rear speakers?
if you have an aftermarket and are using low level inputs (RCA) voltmeter them suckas and see if theyre pushin. other than that double check all your speaker wiring you have done and see if its there. my guess, if youre runnin it in 3 channel mode you got your wires confused.
R.I.P.
