Hooking up subs and amps
    any body have ne good links or pics on how to hook up subs and amps directly to the deck? i been readin on the internet, but couldn't find anything that helpful. i can connect it externally, hooking the amp up to a switch, and then to my battery.
    thnx
    thnx
    Connect the remote wire from the deck to the remote wire to the amp. Remote wires are usually blue. Then just find a way to hide the wires.
      thnx. so instead of connecting a wire from the positive to the remote within the amp, i would do a direct connection to the deck. that wouldn't eliminate the line level and stuff tho right, my other setup with the rca conversion is needed?
        BASIC
        More complex
        My Ride...
          Your amp should have a slot for the power wire and a separate slot for a remote wire. Remote wire powers the amp when the headunit is on so its not on constant as if you were to power it from the battery. RCA should be the same as running the remote wire.
            [QUOTE=93_EXR.]BASIC
            [QUOTE]
            Lol...that diagram rules! how much more basic can you get?
            Lois: Oh, I haven't been on a college campus in years. Everything seems so different.
            Stewie: Really? Perhaps if you laid on your back with your ankles behind your ears that would ring a few bells.
              Easiest way of explaining it is..Blue wire from deck goes to remote on amp, positive goes to Plus on battery, and ground goes to any metal on the car..
                thnx a lot guys. ill try it out an see how it works
                  how do u hook up the fuse box and fuse? isn't their already a fuse in my amp??
                    Originally posted by 93_EXR.
                    BASIC
                    More complex
                    is the capacitor "required" when hooking up a sub? I currently have a bazooka sub and its making like a "thud" "thud" noise continously. when I lower the sub volume it goes away. when I remove the rca feed it still makes that sound. anybody have an idea what is it?
                    Sky rockets in flight..... afternoon deeeelight!!
                      You need to make a better ground point. Where ever you have your amp grounded, remove it, sand the paint down to the metal and reground it. Also be sure the terminals are tight and not loose.
                      Hope this info helps.
                      Black Housing DIY 1991 Wagon Morimoto Retrofit
                      JDM One-Piece Headlight Lens Repair
                        ---> You should always put a fuse right off the bat.+ won't short or kill your amp,
                        --->The caps just help not go through altinators so fast
                        If your pumping your music and you lights dim abit then i would get a capacitor,
                        And makes your bass sounds more solid, because its not running out of power
                        Cheers
                        My Ride...
                          Check out www.the12volt.com
                          MYCB7.com
                            Thanks I found the problem.... the ground connection was loose and now I got good bass again.... thanks for the info
