S2000 Antenna Install........OEM wires?
    90 EX Coupe with an S2000 antenna. The coax wire, no problem. What about the three OEM wires from the stock harness? Black = ground, right? What about the other two.
    Yes the S2000 antenna has a yellow wire on it for the "booster".
    After 17 years and 208K miles, I'm not "tuning" my CB7, I'm "restoring" a CLASSIC.
    Not sure but check the DIY section, I'm sure you should find something there.
    1992 Honda Accord Coupe LX
      Found a DIY... Its an old one so the pictures dont work any more but it might help a little. http://www.cb7tuner.com/vbb/showthre...ntenna+Install
      EDIT:Found a more recent one. Pics still work. http://www.cb7tuner.com/vbb/showthr...ght=S2k+Antenna Good Luck.. Later
        that second link wont work for me
          Thanks.
          I'm really only using this antenna for my Sirius FM modulation setup. I guess what I really need to do is use the CD changer port and hardwire my Sirius into the OEM Civic radio I have installed in my Accord to aleviate my noise issues.
            S2k Antenna
            Hey yall i did the second DIY on this since the older one has no pictures.
            here is the link:
            Antenna
            As far as wiring i did this myself and i hooked up the power harness rca to the antenna since it has its own booster...i didnt hook up the power for the antenna to raise or that see through tube because its obviously not a stockie....
            well if you need anything else answered id be glad to help...pm me or catch me on aim!!
            Ralphie.
              Yea, saw that link Ralphie, thanks. FM reception is pretty decent but for some reason the FM modulation from my Sirius unit SUCKS. This may be a DC Voltage noise issue.
                plug ur fm mod as close to the radio as possible
                Member Ride Facebook
                XBOX LIVE = RedDragonsFool
                SOLD MY CB JUNE 16, 2009
                For Sale Thread
