Bouncing tach
    Bouncing tach
    when i bought my car it came with aftermarket gauges and im not sure who installed them... they work great except for my tach goes crazy some times... rarely it will work jus fine but most of the time after i get to about 4k it starts bouncing up and down until i shift and then the rpms go down and it works normal..... does anyone have an idea on what this can be?? thanks in advance for the help
    91 ex coupe
    kyb susp.
    custom intake
    spoon sports header
    custom piping
    exhaust tech muffler
    3 piece strut
    optima yellow top
    B&M short shifter
    Check your engine ground thats on the engine block. Or maybe your altenator is about to crap out on you. And check all your grounds thats what happened to me.
      Aftermarket tach? You did not specify whether it's the factory tach or an aftermarket piece....
      Also, any loss of power i.e. studdering/missing under a load at or above 4k?
      Could be a ground, could be the ignitor in the distributor.
      1992 Accord LX - SOLD
        sometimes it does stutter a little bit above 5k... they are after market gauges but theyre jus for looks its not a tach mounted outside of the gauge cluster
        91 ex coupe
        kyb susp.
        custom intake
        spoon sports header
        custom piping
        3 piece strut
        optima yellow top
        B&M short shifter
