Weird Stuff happening with 4 ch. amp
    okay, I just installed my 4 channel amp...its working good Ithink...however, when I turn on my lights, and turn down the headunit, I can hear a buzzing sound because my lights are on...why is that???
    Yeah, Preludes
    Originally posted by deevergote.
    Why can't people just search OT to see if someone else posted the same random thread?
    probably a poor ground. or a crappy amp. or maybe crappy RCA's, i dunno. later.
    Avoiding dirt at all costs
      how'd you run the power line for the amp, and the cables for the amp? if they're running right next to each other, that can produce a buzzing sound. well so i heard, on crutchfield. might wantto try running them on opposite sides of the car? it'd be a pain in the ass, but lets just put that as a last resort.
      but check the ground, and the RCA's. if that stuff doesn't work, try to get a different amp in there just to test it, and see if theres still a buzzing sound. if there is, get a new amp.
        cheap ass rca's can do it as well.
        is the amp a MTX by the way?
        sometimes if you tried what they said by seperating the power and rca and it still is there, then sometimes it can be the deck or the amp itself, i usually take a wire that is attached to metal at the decck, and then wrap the outside of the rca terminal, basically i make a ground loop isolator and if the problem was within the deck then that solved it.
        heheh
        Retro!
        Hater
          well its kinda like this though:
          when my head unit is on, and my lights are off, there is no buzzing sound.
          however, when my head unit is on, and my lights are on as well, when i turn down the volume of my head unit, I can hear a slight buzzing sounds, because the light is on. I know this for a fact, because when the lights are off, there is no buzzing sound. Weird eh? My friend who helped me install it says he's never heard of this
          Yeah, Preludes
            actually i've seen it alot. that sound is from inteferce from the alternator. u get that when u run the power and rca cables down the same side of the car. the must be on seperate sides. if they are on seperate sides it may be the rca's themselfs. most of the time if u have a bad ground u get noise from the engine mixed in with ur bass not that buzzing sound.
              ij ust thought I might be using too much power but I don't knw lol
              Yeah, Preludes
                does
                does your headlights dim when the bass hits? thats pretty much how you can tell if your using to much power, in which case the best route is to get a capacitor, which I recomend anyways just due to power usage of the entire car. But yes the best way is to run the rcas vs. power wires on opposite sides of your car. Good luck!
                MadLab Racing
                Southern Maryland
                  i had that same thing happen to me couldnt figure it out for the longest, so i nevered turned down my music...lol
                  but heres some fixes, or at least what i did to fix mine
                  1. the ground wire needs to be grounded very well, try 1 of those holes in the trunk w/ a nice big screw(also make sure theres no paint, just metal, PURE metal
                  2. NEVER run ur pwer stuff on the same side as the rca cables, u'll also get a hummin sound when u turn it down, not just when the lights are on....annoyin as hell
                  3. like everyone said, really crappy rca cables, just change em
                  "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
                  I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
                    honestly, i always run the power with the rca and never had an issue, though i use good rca's but sometimes in some cars it dont work that way haha.
                    Retro!
                    Hater
                      w/ the RCA cables, it depends on the insulation of the cable, plus the fiber wires inside, IN OTHER WORDS, u get what u paid for
                        sometimes it does, but there are rca's that are 120 bucks which i think are just wayy too much...i think around the 40 dollar range is good...lol
                        Retro!
                        Hater
