Fuse question for H/U
    I have question about fuse. Is it fine to use a 30 amp fuse instead of 20 amp fuse for direct power from the battery to the H/U? My H/U is Alpine cda-7894, and the installation guide says that I need to use 20 amp fuse. How does a fuse work? Is it the bigger the amp the better it take the current?
    I am using streetwire cable with an AGU fuse holder and the kit came with one 30 amp AGU fuse. I searched at my local electronic store, autozone and they do not have a 20 amp AGU fuse. Do they make 20 Amp AGU fuse?
    Help would be appreciated.
    http://auto.howstuffworks.com/wfc2.htm
    No its not ok to use a bigger than necessary fuse. That would defeat the purpose of the fuse. In fact, its better to use a smaller fuse than a larger one.
    Did you check an electronics store?
    YouTube Clicky!!
      I checked electronic stores and asked the clerk and they said that there are no 20 amp AGU fuse. They said that AGU fuse are rated min 30 amp, 40 amp and 60 amp.
        he is full of shit there is one right here in front of me, and heres one online http://www.hifisoundconnection.com/S...32247242249238
        FA1
        355
          That was what I thought, too. Because I told the clerk that on the internet they have it, but still they 100% sure that there are not any AGU fuse with 20 amp. Well since I am not an expert in this, I just got out from the store with a lot of confusion . Thanks for the confirmation.
            Those alpine head units dont really require that you use the 10 gauge wire. Stock wire is fine BUT its safer to use the 10 gauge. If you cant find 20amp AGU just get a blade fuse holder and it should come with 2 pieces of 10 gauge wire on the ends and use that.
              Is it this kind of fuse holder?
              The one that I got is this one:
              Thanks for the help
                Yes thats the type of fuse holder, just take off the agu fuse holder that came with your kit and use the blade type holder and ur problems are sloved. Also the blade fuses are cheaper if u do manage to blow the one that you are using.
                  Thanks that is really helping me.
                    Yea with fuses if you dont have the right size always go smaller because if you use a larger fuse and god forbid you have a problem the fuse wont blow and in turn the wire will start to burn and damage everything in contact with that wire. On the other hand with a smaller fuse it will def. blow the fuse. Just my 2 cents
