6x9's. help.
    6x9's. help.
    ok i have 2 kenwood 6x9s. i was wondering if their is a way i can put them in place of the back speakers of a 91 honda accord lx?
    THIS IS ONLY THE BEGINNING!!!
    Take the cover off the rea speakers and compare. I believe all speakers with the same measurements use the same bolt patterns... if not, then you might have to frill new holes. Some speakers also com with their own covers... If your speakers won't fit the original covers, then use the ones with the speakers, if yours came with them that is.
    If you've got a problem, I might have an answer... or a sledgehammer.
    (a little dirt goes a long way)
      hit it with a hammer. several times. I have unprotected sex with multiple partners. And my life will turn out for the better
        I have an LX that housed 6.5's .. I installed 6x9's by simply using a dremel .. and
        making the hole larger .. BUT .. make the hole's larger toward the *front* of the car.
        The two bars that run across the trunk .. could impede installation .. easy to do ..
        A Hui Hou !!
        Tomi
        My CB9/Wagon Thread Start to Finish:
        http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
          I've got a '93 EX. Would that make it 6.5 in the front and 6x9 in back? Just want to make sure I buy the right speakers.
          generic short-ram
          generic strut tower bar
          hid bulbs all around
          amber bumper + clear corners (soon to be amber)
            You do have 6x9's in the rear deck .. but there seems to be 2 different sizes in the front of EX's.
            Two links to help ya ..
            http://www.cb7tuner.com/vbb/showthread.php?t=50120
            http://www.cb7tuner.com/vbb/showthre...speaker+sticky
            Better yet .. remove your front panels and take a gander ..
            A Hui Hou !!!
            Tomi
              5 up front and 6x9 out back. Thanks. Now I just need to find some damn good speakers lol.
              edit*
              Would that be 5-1/4 for the front?
              generic short-ram
                edit*
                you may have to cut the speaker pod a bit. you could always pick up some LX pods or simply some spacers to fit 6.5s and just trash the ex pod.
                FA1
                355
