Ok I finally have all my speakers. I need to run my 4 gauge wire for my amp. Since the battery is on the passenger side is there anywhere to run the wire through on that side? I would hate to have to drill a hole in the fire wall and use a grommet.
Where to run power wire for an amp?
I just ran the wire over to the drivers side and slipped it in between the firewall and a grommet already being used with a bunch of wires running through it.
You are most likely going to have to go over to the driverside because the passenger side can be a real bitch to drill anything through with the heater cor and a/c stuff all right there.
Originally posted by Cletus VandamnI just ran the wire over to the drivers side and slipped it in between the firewall and a grommet already being used with a bunch of wires running through it.
i just ran mine through the drivers side, i didnt want to mess anything up, and i had enough wire, just make sure if you do drill a hole you use a gromit, you dont want to have your power wire ground it self out....-RIP Eric Hall. Miss you brother-
newskoolhippy (10:53:37 PM): i want to see a pic of you with a hard-on to prove thats your cock
newskoolhippy (10:53:56 PM): i need to see your face in the pic
newskoolhippy (10:54:07 PM): with todays paper in the picture to prove your taking it now
Originally posted by turboh22aakkordhey man.. i jussssst got done running 4 gauge wire annnnd 1/2 air line to my trunk from the pass. side of the car... i have a 92 LX and on the fire wall there was a rubber plug type of thing that popped right out and i ran the wire/lines through that.. i have a chipped ECU and my computer sits on the floor so i dont know if you will have to unbolt the ecu to get to that hole or not.. but if you look below the glove box where the the fire wall is you should see that plug and it should pop right out with some pliers! good luck..
there isn't a "right" or "wrong" way, but there is a "easier" way...simply pull back the carpet in the passenger side underneath the glove box..you should see a lil black rubber grommet..pull it inside because i do believe its 2 parts...then just leave the outer part to protect the wire and run it thru there and down the passenger side of your car...i'll get some pics of it to show you..
well in my 90, i ran the wire from the batt to the driverside(up the rt fender, then along the top), cause i found a hole already there with a cover on it near the pedals/exsisting wires) on the driverside..so i just had to open it and run it in there...
then i ran it toward the shifter...tucked it under and the amp is under my seat
Originally posted by JusTy13oiwell in my 90, i ran the wire from the batt to the driverside(up the rt fender, then along the top), cause i found a hole already there with a cover on it near the pedals/exsisting wires) on the driverside..so i just had to open it and run it in there...
