Where to run power wire for an amp?
      Originally posted by visualpoet View Post
      Could you get us a pic from the engine bay side so we can see exactly where the wire is coming through to?
      Also, what are those 3 black wires for?
      Thanks.
        i also ran mine through the driver side...i used black zip ties to hold it up without being niticed so the only part u can see of it is on the battery terminal
        IM IN LOVE WITH A CAR..IS THAT WRONG?
        MY MR THREAD
        http://www.cb7tuner.com/vbb/showthread.php?t=132771
          Closer look:
          One of those black wires is from the control box for my undercars, one of them runs from the undercar sub-control back into the car for the LED strip in the trunk, the last one is the wire I used to run power from the switch out to the fogs I had on the car. It's unhooked but not removed from the car.
            Closer look:
            It looks like the wire is coming out from the bottom of the vaccuum pump and next to the fuel filter. No wonder I could not see it.
            I see that power cable does not looks like it's going into the battery but into the fuse box? Is that correct? Is that a better way to connect the power cable?
            Thanks for the nice pics.
              You could always drill a hole in the grommet so the power wire doesnt ground itself out.
