Suggestions Please
    Suggestions Please
    I am looking at these right now
    http://www.crutchfield.com/S-SDHmCOg...1671&s=0&cc=01
    Should I run a 200x4 amp through all of them and then put bass blockers on the doors because im going to put the speakers in the doors and the rear deck.But I was thinking sinse all the speakers are the same to just run them all off the deck and buy a sub later that way I will not get distortion at high volume levels but the Sub will give the bump I want.
    spring for a nice component set that has a mid bass driver, and tweeter. you could probably get a nice set off of ebay for a decient price.
    http://www.cb7tuner.com/vbb/showthread.php?t=22013
    cb7tuner.com Cleveland division
      running speakers with rms rating beyond 25wRMS off of the HU will cause distortion at high volumes..you need to get a 4-ch. amp for your speakers..if you have 60wRMS speakers, get a 50x4wRMS amp, that will sound so much better and louder and that will get you set up correctly for a sub..
        im with mondo, id also like to add bassblockers are a waster of money and if you add a 4 channel amp they usually have a adjustable crossover
        FA1
        355
          werd..
            Heres an amp http://www.crutchfield.com/S-1hNYdUU...0&I=130GM6200F
            And heres the speakers http://www.crutchfield.com/S-WswN2I2...1681&s=0&cc=01
            but it said these speakers wont fit the door so would I be able to go with Pioneers other speakers it says that those will fit http://www.crutchfield.com/S-WswN2I2...0&I=130TSA1671 so i would have the 4 way speakers in back and these three way speakers in front with the amp wich is cranking out 60 watts 4 ways for each speaker.
              is that 60wRMS..sorry, but im not one to click links...they waste too much time..
