I want to install a switch for my remote wire and put on my dash, or somewhere like and i was wonderin how do i wire that; i see the 3 prongs coming out of it, im definately an audio beginner, so i dont know how to connect the wires or anything..any help would be nice.
Stereo Switch
http://www.bcae1.com/switches.htm
that sums it up
edit:
I have used the "lighted toggle switches" before, have one for my cooling fans. Usually you have your power source (from HU) on the end, the the power out (to amps/antenna) in the middle, and a ground on the other end.Last edited by aero; 03-25-2006, 10:48 AM.
Originally posted by aerohttp://www.bcae1.com/switches.htm
that sums it up
edit:
I have used the "lighted toggle switches" before, have one for my cooling fans. Usually you have your power source (from HU) on the end, the the power out (to amps/antenna) in the middle, and a ground on the other end.i see the 3 prongs coming out of it
Originally posted by zelsemanThat link didnt seem to informative..., and the bottom part just restated what i already knew:
And what i need to know is:
anyone else know of how to do this?
The switch should say which one is for ground, if not, hook it up, if it doesnt work, switch it around the other way.
But you will put your wire going to the headunit on one of the end prongs
The wire going to the amps/antenna will be in the middle
and the ground will be on the other end prong.
edit: the little diagram thing on the bottom of that page shows how, the battery/fuse line is the "incoming" or from headunit. The one that is connected to the light is the "outgoing" or where you want the power to end up, and the short one with the down arrow(ground) is the ground wire.Last edited by aero; 03-25-2006, 08:53 PM.
Originally posted by zelsemanI want to install a switch for my remote wire and put on my dash, or somewhere like and i was wonderin how do i wire that; i see the 3 prongs coming out of it, im definately an audio beginner, so i dont know how to connect the wires or anything..any help would be nice.
If imitation is the best form of flattery............thanks for kissing my ass.
Originally posted by jdmkidi think its so he can listen to his sub wihout using the headunit and turning the sub off? iono
listen to sub w/o hu?
i have mine on switches to but tis incase i dont feel like hearing it and bc i have EVs wich are loud and i can shut them off ifi get pulled over, or if my daughter is in my car
Originally posted by jdmkidno what im saying is aftermarket headunits have built in switches were you can turn the sub off which is what he wants to do
ont all have it though. my jvc dgifine did. my kenwood tv no clue there is to many features on it, i think i could if i went to a certain screen and put the sub level at 0 but it sto much work
Originally posted by R33cb7Why would you want to put a switch to your remote wire? That makes no sense. Your radio should turn your amp on/off with the remote wire it already has!
Originally posted by aerowell, like I said above, you will cut the remote wire, and you will then have one wire going to the headunit, one wire going to the amps/antenna, and you will need to get a ground.
