Auto seatbelt won't retract
    I need some help on this one, my seatbelt won't retract when I shut my door, I have to push it back but the pass side works and it goes forward when I turn off key or open door, I really don't think it's a fuse but I could be wrong
    Does the door switch correctly operate the courtesy lights (door open indicator stay on when the door is shut)? If the switch is broken, the car may not realize that the door is closed. I'm not sure off hand if there is a separate fuse for each side, but check it anyway.
      Nope the door switch may be bad cuz it doesn't show on dash no CL either
        And I just went through and checked all fuses, it's a pain to pull it back every time you open the door
          take to stealership they will fix restraint system for free
          (129)Transactions and counting
            Seriously the dealership will fix it for free?!?!
              They may. Some components are covered, some are not. It wouldn't hurt to do a little research on the matter, and take it in to see what they say.
              Some dealerships may go above and beyond, recognizing that you drive an old car that may soon need to be replaced... so taking care of you is a great way to encourage you to buy your next car from them!
                the way i see it. its a safety concern that has the safety of the occupants in question from something they designed so yeh. have em check it out. i had the one in my subaru replaced free of charge
                  life of car warranty
                  its covered here on the forum
