Power window rolls down but not up
    So..my 92 ex coupe has powerwindows, the passenger side window rolls down, bit not up, first initial response was to replace the motor, after replacing the motor, the window only responds to when i press the switch to roll the wondow down, nothing happens when i press it up to roll window up, this is the same for either switch (driver,passenger), ive checked every fuse not one single fuse is blown or discolored, sorry if this has already been discusses but its harder to search when using my phone...i dont have a back button thanks
    Tried forcing window up and it will not budge at all, been keeping a plastic bag over window to keep rain and leaves out, but thats not going to stop a thief, garage is occupied by my chrysler crossfire as i due some maintenance before i sell it, any help please
      I've had some luck with cleaning the window tracks, even to the point of taking the glass out and cleaning the entire length of the track. You can use some graphite in the tracks to help lubricate them as well. Check to make sure the track liner is in the proper position and not bunching up - on several of my Accords I've had the front window track liners start to bunch up at the corner above the mirror. Solution was to go inside the door and reposition the track liner using a little spray adhesive to keep it from migrating upward.
      On other Accords where the window was just getting slow, on a tip from a guy at work whose brother details cars (lame path of credibility, I know), I cleaned, then lubricated the exposed tracks (just rolled the window down) with regular ArmorAll - the window worked much better after that for quite a while.
        You could have one of 2 issues. Your switches could be bad or you might need a new regulator. Most of them come with the motor attached. I would check with rock auto. Most of the regulators have been discontinued by Honda.
