Car Alarm or No Car Alarm
    So I have been shopping around for car alarm system, and doing my research but am stuck on no auto start or auto start. So my question is can you put an auto start on a manual or no. I asked around but it spit, so I figured I would ask here with more experienced how da owners.
    The simple answer is yes.
    The more detailed answer depends on the system. I installed my compustar remote start years ago when I was a noob. It was a really shitty install but it still worked flawlessly. I have since removed it and will probably upgrade in the near future
    YouTube Clicky!!
      Yes you can put a remote start on a 5 speed all you need to do is by pass the clutch switch, but one thing you need to know and make sure you ALWAYS remember is NEVER leave it in gear when you park it because then the car will move forward trying to start until you shut it off or it crashes into someone of something, that's why it is not recommended .
      I have a viper remote start installed on my 5 speed and it has happened to me which is why now I lend no one my car and I don't have the habit of leaving it in gear.
      CLICK ON SIG FOR MEMBERS RIDE
      "2SIIC"
      Authentic Jerseys for sale
      http://www.cb7tuner.com/vbb/showthread.php?t=188314
        Thanks
        Nice, well I have been shopping viper alarms, and found a few but wanted to make sure I could install on manual.
          You don't have to bypass it. You use one the output signals from the brain to activate a relay which "presses" the switch automagically.
          And most modern remote starts require some type of safety interlock or pattern for manual transmissions.
          YouTube Clicky!!
            I don't now
            Since I start driving my manual only for a few weeks now, I haven't gotten into that habit. I have done it once or twice cuz a buddy said I should but I dont. Thanks big piece of advice on that one, don't need that.
              Thanks
              Using a pin from the brain sounds cleaner, I'll be sure to make sure the tech I have do it does it that way. Not one for half fast wiring. Thanks again guys.
