When i bought my car the rear windows weren't rolling down. Where do You guys suggest I start my troubleshooting? What would it most likely be i'm sure there aren't many things it could be i'm just not sure haha. Also the cabin light doesnt work maybe suggestions for that too. Greatly appreciated it's always nice to have an idea of where to start.
rear windows don't roll down
If your fuses are all fine, a digital multimeter will be your best friend. I would start with the switches in the driver door and test to make sure that they are operating properly. If they are, move to the wires in each rear door and make sure they have not grounded out somewhere over time. In terms of your dome light... No offense, but have you checked the bulb? If it "appears" good, still try a new one. Filament can be a sneaky S.O.B. If you have tried a new one, make sure it is getting the proper voltage as well with your dmm. If not, work backwards to your selector switch on the dome light, the steering column switch and so on... Also, make sure you are doing all of this in the "ON" position, not the "off" or "door open" selection. Good luck!
