Remote start help Please!!!!
    Hey guys i'm new here and I figured this is the place to go for help! This is my first remote start install and having some issues. I bought the viper 5101/python 1401 remote start and keyless entry system. Locks work great but when I activate remote start it flashes once, gauges light up I hear the viper unit click but then everything shuts off. Does this 2 more times and then re-locks the doors and shuts off. I'm having trouble finding out what wire goes where, Its the heavy gauge 8pin H3 connector
    1-pink -- ignition 1 input/output
    2-red/white -- + fused ignition 2/flex relay input
    3-orange -- accessory
    4-violet -- starter output
    5-red -- + fused ignition 1 input
    6-pink/white -- ignition 2/flex relay output
    7-pink/black -- flex relay input if required
    8-red/black -- + fused accessory/starter input
    Currently I have the following wires connected on the ignition harness, if anyone knows please tell me what I did wrong, would be much appreciated!!! thanks!!
    1-pink --- Black/Yellow
    2-red/white --- White
    3-orange --- White/Black
    4-violet --- Black/White
    5-red --- White
    6-pink/white --- Yellow
    7-pink/black --- None
    8-red/black --- White/Black
    The red/blk wire is a 12v input and needs to be connected to the white 12v feed. All red wires connect to 12v constant.
    You also need to ground the blk/wht wire and connect the brake wire before it will work.
    Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
      So keep all my other wires where they are at, and run the rest of the red wires to constant power? I will try that.
        awesome!!!! it works great!!!! thank you thank you thank you!!!!
          My bro just installed that on my cb and itits
            My bro just installed that on my cb and its fing baller. Intergrated a kill switch to it if the alarm is not taken off the car will not start
