can somebody tell me a good place to put my ground wire around the trunk area?
Grounding Aftermarket System
pretty much any bolt you can loosen and wrap a wire around will work fine, all you have to do is make sure the metal is clean. some people will recommend certain bolts over others, but the whole chassis is one big ground, so it really doesnt matter.
Get to the welded subrame if you can rather than grounding to a bolted on sheet metal part.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
I did mine on the back seat bolt on the passenger side, gave her a good sanding and it works for me.MRT http://www.cb7tuner.com/vbb/showthread.php?t=202004
1992 Accord EX(Canadian)Seattle Silver sedan
Originally posted by ShowStopper71z2 View PostMake sure you use a ring terminal and put the bolt threw the terminal. A good ground is key. You want to sand the area down to bare metal so there is good contact also.
C-3PO's MRT USDM yo!
