I've been thinking about deleting the factory radio for a few weeks now and have a question regarding my options. I usually only use my Ipod for my stereo to begin with so losing am/fm won't really be a problem, so I was wondering Is there a kit to delete the factory head unit and still have an aux port? Or will I have to custom this little project...
Radio Deleting Options?
Here's what I'm working with tell me what you think.
http://www.cb7tuner.com/vbb/showthread.php?t=193759Tags: None
Originally posted by Timothy Watson View PostI've been thinking about deleting the factory radio for a few weeks now and have a question regarding my options. I usually only use my Ipod for my stereo to begin with so losing am/fm won't really be a problem, so I was wondering Is there a kit to delete the factory head unit and still have an aux port? Or will I have to custom this little project...
Right . . .
How exactly do you plan on hearing anything from the speakers without the stereo amplifying the headphone signal?
My 5.7 LS1 Holden Ute
I took a robotics class back in high school (tech school) and we were allowed to choose which circuit to build as our final project I was thinking if there wasn't a kit I could build on of these
http://www.electronickits.com/kit/co.../ampl/k100.htm
Then splicing wires to take rca outputs to the speakers (or small amp if needed) and buying a RCA-AUX cable to mount incar for Ipod input.
The entire point for me is to have room for gauges without going with pods or dash mounts.Here's what I'm working with tell me what you think.
and to address the issue of a power supply I could wire in a Variable Resistor to the carside stereo harness, tune to the correct voltage, and wire directly to the circuit.Here's what I'm working with tell me what you think.
If you pull this off let me know. I've had the same idea but no time to remember to look into itMy 91 ex coupe
http://www.cb7tuner.com/vbb//showthread.php?t=189841
Will do when I get the money to do It I'll definitely give it a go, I figure that would give me room for gauges and would eliminate the antenna. I wonder what people would think if they saw a car playing music with no visible source...Here's what I'm working with tell me what you think.
Why not just buy a small 2 channel amp and a RCA to 3.5mm cable?
I guess because I like to make things, and make them difficult. I think you should be able to do it that way just get a Aux cable female to female and run it to the amp (alot easier to tuck than other options) and get a male aux to rca male cable for the amp input. You'd still have to run the wires to the speakers like any other amp as well though. Still getting rid of the factory head unit, volume control on ipod, and you could tuck the connector, to plug your ipod in, wherever you wanted it to go... It's genius, and nothing short of it. I will be attempting this when i get the money. Thank you sir for helping me not do a lot of unnecessary work. Though a Homemade stereo circuit light up with some light behind a clear plexi-glass panel would add a nice touch...
You could even get a male aux to female aux so you wouldn't have to have another cord... Lets just say I've been up for quite a while...Here's what I'm working with tell me what you think.
Keep in mind that most car speakers are 4ohm while most home audio amps are designed for 6-8ohm speakers. You can still run 4ohm speakers with it but you run the risk of the amp overheating unless you keep the volume low.Last edited by AgentHydra; 09-01-2012, 09:24 AM.
Now, If i understand it correctly ohm refers to the actual resistance of the speaker coil correct? so would it be possible to wire a resistor in circuit? Or do they make 6-8ohm car speakers, that would apply well in this application?Here's what I'm working with tell me what you think.
Did some searching around, found this on Yahoo answers
If you add a resistor in series, you will get higher or lower voltages at the speaker, miss-improving the frequency response.
Verify that your amplifier is capable of driving 2 Ohms. If not, at low loudness levels may be OK, but close to the amplifier's max rating, the current through the output transistors would be excessive and will burn them.
rest of thread
However, some amplifiers are designed to work with both 4 and 8 ohm loads.
For example Topping TP22
Many of the Topping Class T amps will drive a 4 ohm speaker and they have a few different wattage-versions available.
Originally posted by Timothy Watson View PostNow, If i understand it correctly ohm refers to the actual resistance of the speaker coil correct? so would it be possible to wire a resistor in circuit? Or do they make 6-8ohm car speakers, that would apply well in this application?
The speakers ohms value changes as the cone moves, so a fixed value resistor wouldn't work anyway.
Here is a Forum where someone has done it...
http://forums.iboats.com/showthread.php?t=298625
I know it's on a boat but he did use a auto amp, so it will work just need to figure out the tuning for the best speakers for this application.
Found a link on a similar forum to the one mentioned above.
http://www.ipodcarpros.com/p583/iAMP...duct_info.html
There it is all the wires ready to go, with a flush mount volume knob, and you could always put a lighted rocker in to cut the amp on and off.Here's what I'm working with tell me what you think.
Running an Ipod without a head unit has drawbacks. I typically don't recommend it since it costs more to do it right than just buying a head unit.
If you use the headphone out it is already amplified and has distortion issues, sounds bad.
If use use the pre amp out, the signal output is very weak by todays standards and there is no volume control. You need larger amp than with a normal headunit
For those who refuse to listen i use a Pac IS76 dock connector, Pac LC1 volume control, and an amp. If using multiple amps then a line driver should be used like an Audio Control Matrix Plus.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
