Running on Battery only no Alternator
    Ok so...
    I installed garret t3t4 on my h22a. I have downpipe but cant fit it past my cross member. Now I am running open turbo until the shop tells me my parts are in. I killed alternator(push started car, unpluged battery car dies). a day before my parts came in So now im charging my battery and i was wondering how long will my battery last on full charge and no atlernator. I won't have lights or radio on.
    Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
    den das al u ned u no dat u get wurs gas milge tho rite?
    Each time you drain it, the battery will last shorter and shorter until you finally kill the battery, hope you carry jumper cables but even then a jump will only get you MAYBE 5 mins from dead up the road.
    Car batteries are not meant to be fully discharged, your going to spend some $$ on batteries later.
    Go to a junk yard, buy 3 used batteries, charge them, keep them in the trunk in plastic pans, then just swap out as needed if you are driving more than 15min up the road if you MUST drive without an alt. But what a pain in the ass!
      I ran mine for an hour because i forgot to put the alternator ground back on and i had tape all over it. It turned of but turbed back on so i tought it was something stupid. Got home and notice the ground wasnt back on im not sure how long it will last like that. Dont full throttle it. That's why mine died. I stayed under 3k rpms and it got me home.
      Mine does not have a turbo of course so im not sure you can relate to it.
      10th Anniversary Accord.
      05 Audi A4 Ultra Sport 6MT.
        well im guessing i actually killed the alternator a week ago and its lasted me this long, i live like 4 miles from my work and maybe 7 miles from my buddies shop. im hoping to make it to work and then to the shop with out dieing
          See you'll be ok. Just like he said keep extra batteries in case of an emergency and try to go slow on the engine.
            I used to run that way on my race car. Got tired of charging the battery between rounds and put the alternator back in.
            www.850fab.com
            IG - @850Fab
            FB - @850Fabrication
              Update LOL, i dont see the battery light or CEL nothing to indicate my alternator being dead but... Iv made it to work and the battery didnt seem to die any.
              EDIT : Went out and ate lunch battery still lasting pretty good, next stop the SHOP.
              EDIT 2: made it to the shop with no problem.
