So I was installing a radio in my car today, unfortunately the previous owner either did or had a really bad job on the stereo they had in there. Lots of electrical tape and loose wires AND they tore out the original harness. So I had to wire them straight to the car, but it looks like the constant battery wire and 12v switch wire are connected both straight to the battery... and the wire thats supposed to be connected to the switch does not work at all, and does not produce anything on the electrical tester. I tested the fuse and there is a completed current, so it's not the fuse.. any ideas?
12v ignition wire not working
Originally posted by Amiss View PostSo I was installing a radio in my car today, unfortunately the previous owner either did or had a really bad job on the stereo they had in there. Lots of electrical tape and loose wires AND they tore out the original harness. So I had to wire them straight to the car, but it looks like the constant battery wire and 12v switch wire are connected both straight to the battery... and the wire thats supposed to be connected to the switch does not work at all, and does not produce anything on the electrical tester. I tested the fuse and there is a completed current, so it's not the fuse.. any ideas?
Originally posted by Bad_dude View PostHave you test for continuity within the wire itself? Maybe the previous owner was pulling and broke the copper inside. Go over to the12v and see if you could get the wiring color scheme to make sure the wire you are testing is actually the ignition wire.
Yeah, just cut one off at the junkyard before the pigtail and you'll have everything you need. Then you can go kick the previous owner in the balls for being a moron.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
