need help turn signal not blinking
    hello members..got a minor problem which i couldn't solve,my turn signal is not blinking like it suppose to be,its just stays on and not blinking,what could be the problem?already checked the fuses and its still good,
    Does your hazards work? If not, check the blinker relay under the dash. If that isn't the case then replace the actual switch assembly that goes around the steering column. They are pretty easy to replace, just get one from the JY and do what it do. The only irritating part about that is removing the steering wheel.
      hazard are working but its not blinking too..i'll check the relay but which one is it?too bad in my region there is no JY
        the hazzards works but the TURNSIGNAL DOESNT WORK .. right?
        looking under the dash, there is a fuse TURN SIGNALS,, THE FUSE IS NOT WITH THE FUSE BOX, is separated
