Hey guys,
I got the 90 LX Sedan. I want to wire a main relay kill switch as this probably is the easiest to do. I have 2 questions that need help on.
1) Do I go to the relay switch and cut the ground and put a switch in between? What kind of switch should I use and how many amps should the switch handle? Which color wire on that main relay connect do I cut to put the switch on? Has any one done this and have a recommendation?
Beside the main relay kill, which other option would be better and easier? And how to do it?
2) Instead of buying a switch, I want to use the empty spot next the rear defrost switch in the center console area. In that empty area, I have an extra defrost switch, I also have that emergency switch. On the left side of the console, I have only the cruise control switch and the space to the right, I don't have a moon roof so dummy spot there. Should I use the moon roof switch instead as I have an extra cruise and moon roof switch also.
My main concern here is how to wire one of these switches just as a on/off switch. Which one would be easiest to do as an on/off switch? Any diagram to wire the switches on/off?
Here's a picture of the console.
Thanks.
Thanks.
