Power via fuse box
    Power via fuse box
    Im trying to wire in my rear foglight and instead of getting power for the relay directly from the battery, i heard that there are a few places on the fuse box under the driver side kick panel that you can get power from. I was also contemplating running the power wires for my security system from there as well instead of from the battery for a little extra security. Does anyone have anymore info on this and pictures or diagrams as well?
    alarm, tag the ignition harness. More secure.
    As for the foglights, there are ports on the fusebox you can tag with a spade connector. I forgot which one, use a test light to test it. FYI If you dont know how to use a test light, then you shouldnt even be attempting what you are doing.
    Retro!
    Hater
      Ill post some when I get home. Give me a hour....
      My 90 coupe Mr thread....
      http://www.cb7tuner.com/vbb/showthread.php?t=178452
        3 comes on with the headlights. 5 is always hot.
        Member's Ride Thread
        Originally posted by mercyboy
        I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
          Im not sure what you mean by tag the ignition harness. if i really wanted to i could take my multimeter and figure it out but in the interest of not wasting time and not messing anything up, i figured id ask here.
            Aha! Thank you sir.
              Tag ignition harness meaning, splice and solder in directy into the line. If you have a security system and its connected into your fuse box, all someone has to do is disconnect it and its disabled. Having it hardwired into the ignition harness will eliminate that flaw.
              Retro!
              Hater
                Thanks for the info Ander, would have like to known this on Saturday while I was running some new wires. good to know
                  Now is that a fused power source or should an inline fuse be added?
                    Usually I always put an inline fuse.
                    Retro!
                    Hater
