whining noise with stereo
    Originally posted by 93redcb7 View Post
    I also ran the remote wire on the rca side... Does this matter?
    No.
      I doubt it, unless your HU is 500w and your remote is like 4ga.... Do the RCA test though. Unplug it from the amp, rev your car, if the wine is gone, you know it's the ground/bad RCA's.
        alright thanks for the rca test... it was only 1 set that was bad(my 6x9 set) the other set was good.. thanks for the help, close thread
          Even though something is brand new doesn't mean it's always gonna work out of package, sometimes you get duds. Glad it got handled!
            There is a component you can buy from most car stores that connects to your RCA's. It can be called by a few different names but works to solve the interference sound (usually occurs when you start the car engine).
            It can be called "noise suppressor", "noise eliminator" etc. Tell them your problem and they will point you to the component.
            Rides:
            Accord
            92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
            96-AUDM-2.2 VTiS- Heather Mist
            CR-X
            88-JDM-Si- Black
            CR-X Del Sol
            92-JDM-SiR "Transtop" Motegi Edition - Silver
            95-JDM-SiR "Transtop" Daytona Edition - Silver
            92-JDM-SiR "Transtop" - Black
            Prelude
            91-JDM-Si-4ws "Si States" - Phoenix Red
            91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
            91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
            91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
              Is there any wine when the car is just in the ACC position? (I know you said it's RPM related, but .. still.)
              had a similar problem on my friends eg that i installed. and no noise when in the acc position and it was rpm related, when the engine was running. everything else was mint. i did run a new ground from his alternator and problem solved.
              Everyday is one day closer to completing my cb7 <3
                Originally posted by stevediraddo View Post
                This can also be caused by overgrounding. Remember that audio ground and chassis ground must never touch. Audio ground must be isolated. "Ground" parts of audio cables such as the outside ring of RCA cables must never touch metal.
                Except for when pico fuses blow.
                YouTube Clicky!!
                  you can allway run your deck ground to where you ground your amp and a capacitor on you alt. will reduce or eliminate ground noice
