Subwoofer Repair
    Subwoofer Repair
    Is this a pain to repair? The plastic piece in the front just came off so can I just glue it back on?
    It looks to me like its just the dust cap. So yes you should just be able to glue it back on. Make sure you use strong glue
      I'd buy some glue from psi hobby glue extra wont hold up very long. Here's a link http://www.fixmyspeaker.com/ProductDetails.php?pid=946
      My 90 coupe Mr thread....
      http://www.cb7tuner.com/vbb/showthread.php?t=178452
        ive never had any luck with them staying on after gluing them back. good luck and do as they say and get good glue.
          Ive had good luck with the 2 part epoxy from auto zone.
            So is it ok to just use the sub without the dust shield.
              I wouldn't. But it's your sub
                they eventually dont sound the same without it and its alot easier for them to get damaged without the dust shield. i got tired of blowing mine out so i started looking for something different and ended up with titanium eclipse subs.
                  That's why I was just asking lol
                  I have a T1 sitting in my closet, I just want to get the right box for it before installing it
                    My friend had some interfires where the dust cap came off, he took em to an audio shop to get them reglued for like 5 bucks, and he still uses em. That was like a year ago
                      I could think of lots of reasons.... if you useing a sealed box you port out the sub ie damage. Or if its a tuned or ported box you change the hrtz of the box you'll get dust in the motor whitch could cause damage. But it could be fine for a little while I wouldn't do it. The Psi glue I linked you two is highly recomended by pros make shure you clean it well then apply the 2 parts and wight it down so it sticks. That's if you use it ill post a DIY on recones so it's avail for others to try....
                        Thanks for the info bro! I learn something new everyday. Plan right now is to run just one sub and glue the cap on the other, then let it sit over night.
                          its just a dust cover,glue it on.....
                          Only give advice when I know or have done it and it worked
                            It needs to be on there any glue will do...Plus i luv Just loud audio....If you didnt know what JL was
                              Make sure you put weight on the dust cap when you glue it.
                              YouTube Clicky!!
