its wierd stereo problems
    so when i turn on my car the stereo works fine then just out of no where it will start acting up ill hear static in my speakers and my sub will turn on and off ad to keep it on i have to keep my foot on the gas or put it in park anyone had a similar problem?
    Sounds like a couple loose wires behind your deck.
      maybe because my clock is what messed up first
        for the amp turning on and off it sounds like its going to be the remote turn on wire going from the deck to the amp, it should be a blue/white wire coming out of the harness, make sure its well connected. and with the static check all your signal cabled coming out of the harness you might have ignition or battery wire coming in contact with them
          Sounds like loose wires or bad rca wires somtimes you need the ground loop isolater to take out the static noise or you could have a loose connection where the antenna connects together in the trunk or sometimes under the seat or you have a bad antenna
            to keep the radio on you have to press on the brake? grab a dmm and test the power leads on the amp. does it read 12v when the amp cuts out? is the amp clipping or just completely cutting out. how old is the radio. what brand is the radio. some more info would be great. troubleshooting is nevr fun
