speaker size
    speaker size
    hi guys, i keep finding different answers and sizes for the front speakers of a 1993 Accord SE ( bose system )
    Does anyone know the size for the fronts? i know the backs are 6X9's
    i want to replace the fronts because they sound muffled and seemed damaged. from when i bought it.
    ( the right speaker seems fine but the left side one is so quiet, it irritates me when i drive cuz i csn only hear the sound from behind and from the right. and my left ear hears nothing. IT HURTS LOL )
    please someone tell me the correct size! ahha :P
    and any tips when working with the front speakers. thanks guys. i love you all!
    oh and btw. i did get a new deck installed. does anyone know how to get rid of the hissing sound? or static. when no song is being played/quiet. or anyway to recude the hissing. thanks!
    ( kenwood Cd deck )
    Using factory installed Bose Amp - is this causing the hiss?
    Using Infinity 6X9 rear speakers
    Using stock bose speakers ( front) - wanting to replace
    Hissing can probably be corrected by grounding your head unit better.
      U know the size of front speakers varies a bit. I had an LX with 6" fronts. But I've also owned 2 EX's with small ass 4" or 5.5" or some shit in it. Best thing to do is pull the panel off the front door and look in there. U really don't even need to completely pull it off, just get behind the panel right by the speaker and pull it out. Its held in (atleast right there at that point) with a couple of clips that u can pop in or out. Just pull it out right there and look up in there.
        The hissing sound comes from the amp, the factory unit must use a filter, if you can figure out what wire needs it you could add one in.
          it depend i own a 91 LX the front speakers are about 6''
            Front speaker its 6 1/2.. i have change them but get problem because need more spacer to not hit windows when lowering. finaly i have put original one again. and for rear i have change and its 6 1/2 also. i have LX92
              6 1/2? I think..
                they are probaly going to be 6 1/2
                  bose.... no comment. bypass the bose system. once you have done that no hissing sound should be there. sooner or later the bose system will give out. bypassing it will save u future headaches. as far as speaker size i would say 4inch. i personally have a 91 se. and its 4 inch. bose likes to use small speakers and pump em up. take apart the door panels. it will save you alot of guessing time.
                    6 1/2 last time i checked man best of luck... later
