Dome tweeter placement
    I just bought a pair of some Pioneer speakers, model number (TS-A1604C). I am stumped on where to place the tweeters that came with them. I figure I'll just put them by the top of the back window but my one year old might rip them down. Then I thought of putting them in the top corners of the front window but I rather them be discreet and not cause too much attention. I'm really just looking for a good place to get the optimal sound out of them.
    Any suggestions?
    Near the door handles. That's where i put my tweeters.
    JENNA 91 LX
    RIP 12-11-09 - 12/06/10
    JANE 99 Infiniti i30
    2-9-11 - current
    "Life is simple, you make choices and you don't look back."
      Base of the a-pillars or sail panels
      YouTube Clicky!!
        Are these front or rear speakers? That makes a huge difference... lol.
          Tecnically for best sound reproduction and quality tweeters should be mounted below the woofer, more like down in the kick panel. most however will usually make a fiberglass setup in the mirror covers or mount them in the doors around the door handle area, which is fine. Personally i cut and custom mounted mine in the door panel as far forward and up as possible. You running a crossover?
          Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
          Traded with: Cb7xChun
          Sold to: Rob_is_legend,DaddyO,daheavyking
          Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
          My huge For Sale Thread
            Why below the woofer? I've never heard that one before tbh.
              What's the technicality behind mounting the tweeter in the kick and under the woofer?
              The only reason I didn't say kick is because higher frequencies are easily blocked by objects (legs, bags, paper, etc.)
              YouTube Clicky!!
                It has to do with high sound waves travelling linear and faster than lower frequencies. As long as you have them pointed correctly, the sound from a tweeter should hit your ear closer to the same time as the lower midrange if it is mounted below and further.
                It's kinda hard to explain, but it's all in the mecp master manual, I believe in the section about sound quality and such. It's been a while though.
                  That's in the manual? lol
                  speed of sound=343.2/s and in an ideal gas is independent of frequency.
                  Simply sound travels the same speed regardless of frequency <--for the regular ppl.
                  Anyway I think it has something to do with perceived loudness and phasing and maybe frequency response. I know it has alot to do with wavelengths, crossover frequencies and center to center spacing and of course PLD's.
                  OT: I think I should get my MECP certification. Then I could get a side job doing installs...well that was my random thought of the day.
                  YouTube Clicky!!
                    They are the front speakers. I'm waiting on how they sound to determine if I want to buy the rear speakers. I might just end up getting them anyway.
                    Well I'm no expert at making and cutting anything fiberglass. So I just plan on using some 3m command strips and stick them like that just in case I want to change the position. As for your other question they have an integrated crossover. I'm pretty sure its not the best far as controlling the frequency but I really need some new speakers. I don't plan on getting any woofers in my trunk so I hope these do me well.
                      If they're the front speakers don't put the tweeters in the rear.
                      And luckily you beat me to it, high frequency soundwaves don't travel faster than low frequency ones... That'd really suck, especially if that were the case for light, that'd destroy science .
                      And you really don't want to mount them below. That puts obstacles that high frequencies have trouble penetrating in your way, also makes it really hard to sound right even without obstacles. You have to point the tweeters perfectly to make the sound sound like it's coming from in front of you rather than underneath you.
                        a pillar or the b member?? the one in the middle of the front and rear facing the front thats what id do
                        in the begining...
                          Pull your door panels and use the template that came with your new speakers to cut a hole in your door panels, as mentioed high and up front in front of the door handle JUST like the OEM Integra tweeters. Just measure your template on both sides so the hole is in the same position on both doors and take your time cutting the hole. I was using a razor knife one time and sliced the vinyle
                          Here is an example of what most are refering to......
                          Bought from Darkcloud
                          http://wheelflip.com/r/DrAkE
                            Yea I ended putting them in the empty spot where you hide the wires for the side mirrors. Sounds great!
                              You're right. Like I said it's been awhile. It's not the speed of the sound waves. But it is recommended at the very least to not mount them more than a foot apart to maintain proper soundstage imaging and quality. Most high end factory and aftermarket installs will indeed have them low in the door panel or in the kick panels for a reason.
