Radio Help
    Radio Help
    I cant get any good radio reception from my car to any local radio stations, its like it will be playing but it will cut out randomly for any given time. it doesn't have an antenna but is that really a big deal? Should i try and get one or would the problem be something else
    Picture courtesy of JezzWolf!
    You should get an antenna
    YouTube Clicky!!
      You sure though because I've ridden in cars without antennas and their radios worked fine.
        Make sure the antenna connection is plugged in on the backside of the radio. Whether the antenna is up or not, you should get some sort of reception when its plugged into the radio. Is it an aftermarket radio?
        '92 CB7 H22a M2B4
          In my 41 years of life, I've NEVER been in a car without an antenna that the radio picked up fine. You may have been in cars with the antenna just a fine wire in the windshield or hidden in a fender, but if it picked up fine, there was an antenna. Ive even seen aftermarket headunits that won't even come on until the antenna is connected. Get an antenna and I'm sure that will fix the problem.
            ok, so ill try to get an antenna and if it doesnt work, ill get back to you guys
              So did you figure out why your reception was bad?
              94 UK Accord*Weapon-R Intake*Apexi Exhaust*2 JL Audio 10W0s
