need help subs are shuting off nd back on
    whats up so today my subs started going off nd then after a while go back on i was wondering why this was happing here is my set up i have two 10 audiobahn subs with a 750 watt pioneer amp before today everything was working fine any and all input nd ideas are welcomed and greatly appreciated
    nd ps i bought the package off a friend for $100
    Check and see if your amp is functioning right, may be overheating.
      Check your ground on your amp, I was having the same problem hit it with a wire brush. Now it works great
      Originally posted by Darkcloud
      Wimp go low or go home haha
      Originally posted by cb7_tillidie
      Not a single fuck was given that day.
        how do i cheack that because thats what i think but idk how to check
          the ground is good cuz the amp stays on
            Most amps have a power light that lights up green and when overheated it will light up red. Turn it on and let it play till it cuts off and see if that happens.
              my light is blue when its on and when it stops its still blue i drove with the back seats down nd the rear view poined at it and it jus stays blue any oth opinions?
                iagree it sounds like you are overheating your amp a 750 watt pioneer amp is most likely pumping out 400watts if your lucky,turn the gain down on your amp that should help .
                  what makes u think tha amp is only pushin 400watts and what exactly is the gain nd theres also another knob that i belives say sub boost to
                    First, you'll have to figure out what voice coil configuration has (2 or 4 ohm, single or dual). Then you need to figure if you are running a lower than rated load on that amp. If they all match up, then you'll need to see how long it takes before the amp shuts down on you. If you can play it loud pretty long before it shuts off, it's a voltage or overheating problem. If it has the issues you described right when you turn on your system, then you are running to low of a load or your amp is toast.
                    Sig removed due to excessive size.
                      will the box the subs are in says 600w the amp is a 760w and i had it working for 3 days stright then one night the problem happend i trun on the car the subs would hit then stop then hit then stop and on and off like that as far as the voice coil goes id have to try and look that up. and before this happend i was able to knock it at full volume with no problem let me no if this helps if not then ill do reserch on the voicecoil
                        Get a capacitor. That helps out alot. If you have one you may need to run 2
                        CB7Tuner Resident Gamer!
                        PSN: JDMcb7TX
                          in my opinion what im running dosent require one but i could be worng
                            Most applications don't I just say get one to avoid the problem over all. Be sure amp is well ventilated as well.
                            PSN: JDMcb7TX
                              i have the amp on the back of the subs tomorrow ima check where it vents at nd i got the subs pushed back all the way to the back seats nd i need to get a new fuse to cuz i blew the one on the powerline but what im also gunna do is get another amp thats 600w because the amp is 760 nd the subs are 600
