I'm running a distribtuion block since I have 2 amps for my sub and the door speakers. The sub is a T110D2 and with it I have an older rockford fosgate amp which runs at 500 watts at 4 ohms and 1000 watts 2 ohms. The way it the sub was wired up seemed to have been at 1 ohm but I rewired it to a 4 ohm load because the fuse on the block kept blowing before I did that today. My main question is if this was caused because I may have been drawing too much power or what other cause it could be before I blow something up
Distribution block fuse blowing
It would be nice to run it at 1 ohm because at 4 ohms it sounded like I was just getting bass from the door speakers and I didn't get the T1 again to hear that Or is there a way to wire it up to lets say a 2 ohm load and run it like that? I did the wiring from rockfords wiring wizard and they only show how to do a 1 ohm and 4 ohm load
