door panel to rewire the speaker
    ok well since i got my car i try to put in the radio ok did that, then the speaker ok wow i couldnt find the wire cuz the wiring was ancient so i mickey mouse the wire to the speaker in the rear than the door but icouldnt take out the door panel is this an issue every one has?
    CB7 all day
    You couldn't take the door panel off? It's only two screws and clips.
    YouTube Clicky!!
      There's a screw where the door handle is. There's also one on the arm rest. Then there's the metal bracket behind the armrest the you have to slide the door panel to get it off, IIRC.
      Sig removed due to excessive size.
        yes but you know were the panel for the door mirror welll the door panel get stuck there and ihave to wrestle with it til it broke a little
        CB7 all day
          the piece where the mirror is pulls off before removing the door panel. it just un snaps. just pull gently and it will come right off.
