wideband/muffler interference with speakers
    hello people.....i've been having this interference issue but not only the muffler... the wide band (aem) too!! its like a piiiiiii constant i took out the entire console reinstalled the radio, rerouted the wideband harness and still get that noise i even use individual ground's
    only have head unit, amp 4 ch no sub battery relocated to trunk.
    can someone pinpoint or give me an idea what could be causing noises?
    thankyou!
    Do you have a pioneer?
    YouTube Clicky!!
      What brand/model of spark plugs & wires are you using?
      When do you get the noise, all the time? Or when your "spirited" driving?
      Is the noise your getting coming through the speakers on your stereo? Then this link might help: http://www.termpro.com/articles/noise.html
        sonikaccord Do you have a pioneer?
        i have a kenwood head unit and a profile 4 channel amp
        cloudasc What brand/model of spark plugs & wires are you using?
        i just recently put new spark plugs and wires.. NGK v-power and NGK wires
        the noise is when idle or running both times actually all the time the piiiiiiii is from AEM UEGO and the rpm one from just reving it up...i change ground again to bare metal but still. i have the power cord a 4gauge (on the left side) separated from rca's and speaker(through the center). but i don't get it cuz i had a 10" sub and it wasn't making any noise all i did was add the speaker wires to the amp and another rca for rear output... i deleted the sub. and when i turn of the car with radio on the audio crashes for a bit and comes back up like loosing electrical current.
          [QUOTE=dj_eclipse_303;2589516]hello people.....i've been having this interference issue but not only the muffler... the wide band (aem) too!! its like a piiiiiii constant i took out the entire console reinstalled the radio, rerouted the wideband harness and still get that noise i even use individual ground's
          thankyou![/QUOT
          Do you have the speakers running threw an AMP? or are they just running threw the radio? the reason why i asked is if you are... you have to separate the 12volt power wire from the RCA's. If thats not the case and you are running threw the radio, you are the on the right track checking the grounds, if you have checked the grounds. another thing you can do with your ground, wire is try grounding it some other spot. what you are hearing is caused from a loop of grounds.(make sure the spot where you have the ground is clear of paint or any other debris) if you have checked the grounds and they are all ok then... you me check your alternator. you can have it checked at your local pep boys or automotive parts dealer. thats all i know to do you can check this site it will help you with all things 12volt on a car. http://www.the12volt.com
            tonka9999
            i ran the power on the right side by the passenger and the RCA's through the center by the hand brake together with the speakers cables and yes im running the speaker with the amp
            **radio/RCA's to > amp to > speaker
