speakers stop working
    so today i installed my amp and a sub i connected my amp to my lights ( if is there better connection let me know ) every works good but sometimes my 4 speakers will stop working they just die the sub keep playing the music but everything else just stops the radio stays on but not sound from the speakers ??? the speakers start working but for bit is like they come and go. is my radio too weak for the 4 speakers ???should i just connect the 2 in the back ? and have no doors .. but like the door speakers it just just better all around the car
    First, getting power from your lights is a bad idea; you can cause problems with your lights blowing fuses and/or cooking wires. Take it straight from the battery terminal.
    Second, we're going to need more information to help you. Is this from your stock head unit (stereo)? How are you getting signal from the HU to the amp? If you've spliced into the speaker wires or have a cheapo HU, the problem is probably there.
      ok so i should run another cable to the battery i have the one with the line fuse already there so the other cable that needs power should go to rhe baterry and i have this head unit http://www.amazon.com/JVC-KD-R210-Re...8954961&sr=1-1 with 2 pioneer speakers and 2 Sony xploids ... i will lose sound from the speakers sometimes but the sub will still work ... after like 5 seconds the sound will come back to the speakers but will go bad again
        You should and always get power from the battery.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          but if i connect that cable to the the battery is my amp gonna be always on ?
            No , depends on how you installed the wirings. The remote wire controls the on and off. When the HU comes on the Amp comes on , off and off.
            You should have that.
              oh i have that cable on my head unit ... so i ma put it there and c if my problem goes away
                that fixed my problems but when i hit a pot hole my sound goes off for like a 3 seconds
                  wait what? u connected ur amp to ur lights? do u mean u connected lights to ur amp so they will flash with the bass? another question are your for speakers hooked up to a 4ch amp? u should only have one power wire runing from ur batt to ur amp and it should have a inline fuse no matter what. your deck should provide enough power to ur speakers so its not an power issue. how old is the deck
                    1] You need to recheck your wires for fitment
                    2] Make sure every bolt and screw that secures the system is tight
                    3] I think your HU is taking a dump
                      i already fixed that i connected the amp to the radio remote the with and blue cable from the HU and yes i have my line fuse and all and my deck is this one http://www.amazon.com/JVC-KD-R210-Re...8954961&sr=1-1
                      i ma do 1 and 2 tomorrow i think thats the problem when the sound goes away i tap the passenger side speaker and it comes back
                        Either your CD is skipping - Normal
                        Or you have crappy wiring connections - Not normal.
                        Btw we aren't texting here. Please type properly.
                        My 5.7 LS1 Holden Ute
