Woofer problems
    What gauge are your power and ground wires?
    Also, check your connections as Sonik as has said before.
    If you have a fuse block make sure you're using the correct fuses.
      i had that problem also, its prolly your grounds for your amp
      On To The Next One!!!
        okay new info i found in this section says that i should b at about 13.5v+ however I'm pushing about 12.79v max. I checked connections and everything. What else could there be?
        Member's Ride Thread
        Don't forget to cut holes in the box. Someone sent me a dead hooker one time, and that wasn't cool.
        Bought From: AccordWarrior | CB7lx91 | DarkShadow707| Tn_Accords | H23CB7 | Jack_lee | Fatboy1185
        Sold/Gave To: 90goldcoupe | CB7lx91 | Jas_r34 | F20accordturbo | BatmannamtaB
          12.79 with the car on or off?
          YouTube Clicky!!
            car on sry. also according to my haynes book (looking for someone else) it said that my alt should be in the 12.5ish range with loads off. then if i turn on my headlights it should drop then spike up higher than before. Mine does nothing. So possibly voltage regulator bad i take it according to haynes.
              well it could be your alternator is not strong enough for your amp and chech your ground make sure its good i fried an amp bc i thought the ground was good but it was not a good connection try that then see how it works or just get a compacitior
                A cap won't help...Your batt voltage with the car on should be around 14 ish volts.
                YouTube Clicky!!
