Originally posted by charles.scarlet
View Post
dead alternator due to amp or what? capacitor?
Originally posted by sonikaccord View PostSmall guage wire won't kill your battery...the amp is going to try to pull as much current as it needs regardless of wire size.
The alternator is going to PUSH what ever it needs to sustain what it can. But can only supply what it can based on the wire.
If you have a "6000" watt amp (which is stupid cause its not even RMS) and then you run a small 8 guage to it, you will probably have issues and the amp wont get enough power.
cars should be running in the 13.5+v range and up, not 12.5 If its not best thing to do is first clean up factory grounds that have paint under them.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Posta small guage wire will actually cause more resistance in the circuit because the amp cannot pull enough power to power it. Thus it will lead to heat which leads to more resistance.
Originally posted by accordztech View PostThe alternator is going to PUSH what ever it needs to sustain what it can. But can only supply what it can based on the wire.
I was mainly talking about the amp to battery connection.
Honestly I don't see how people kill their battery unless they are running the system wide out the whole time they're driving. Speakers see alot less power than what people think.
Originally posted by sonikaccord View PostHonestly I don't see how people kill their battery unless they are running the system wide out the whole time they're driving. Speakers see alot less power than what people think.
I have a bit of juice going through my system in my van. The rear amp is a true 1200 watt rms amp and I also have a eclipse 4 channel which isnt that much power at 75watts rms a channel. With my system running I was at 13.3v all the time. Then I made sure all my engine grounds and my battery ground were cleaned and sanded down, that sucker went up to 14.2v at idle. Good enough for me =)
Easy t hings are commonly overlooked, and it costed no money and took a little timeWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View PostI see more people buy capacitors when they dont need it. Half the reason why most peoples lights dim is poor grounds (aside from old worn out alternators and cheap bad batteries). I see so many people ground amps to the chassis and dont grind down the surface to remove the paint or the metal that they do ground to isnt a good ground to begin with.
My left front head light (low beam) and both my high beams were not working 2 days ago untill just tonight i flipped my signal on and there you go, all my lights are working again and have been fine since...
my alarm, my lights, my stereo, and the keyless entry have all been malfunctioning, Im assuming now its a bad wire somewhere, or a bad ground
whatever it is i need to find it and fast, its making my baby look ghetto
