audio problem rear speakers
    whats up i have a 91 dx that i just got relized there is no back speakers i open the trunk the connection is there so i took one of the front speakers and connected to the back and it does not work so i have 3 questions 1. do they come stock with rear speakers 2. where so you install it at because i dont see a spot to support it. 3. what could be the issue?
    Some DX's didn't come with rear speakers.
    There are holes for them in the metal part of the rear deck though. What you'll have to do is get speaker pods out of another CB and install them prior to putting in the speakers.
    Just make sure the wiring is already there. If not, expect to have to run wires to the headunit.
      only issue is if u dont have the patience to run some wires to front if their not in there. other then that josh answered what u were asking.
      Members Ride sold...
      I'm back...... with a coupe. oh boy here we go.
        He said in his first post that the connection is there and he hooked it to a speaker.
        It would help if we knew what head unit you're using. If it's factory in a DX, it probably doesn't have rears or doesn't have them connected in the dash ( no sense sending signal to speakers that don't exist.)
          thanks for the help thats what i thought there is wire connection but when i put in one of the front speakers in there it didnt work so im guessing its not connected to the head unit?
          yeah i had more posts in here but i think they got deleted but that said i was using the stock headunit
            start from the power source....and work your way threw....
            i had a faulty connection....F4T
            [COLOR=DarkRed][B]I LIVE ACCORDINGLY * 93 CB7
              yeah thats what im gunna do i have a aftermarket cd unit and when i get time to put that in im going to check the wiring then....makes sence like visualpoet said why send signal to speakers that dont exist
                you will prolly have to cut up the rear deck and hook up the wires from the back to the front deck if the deck isnt stock
                On To The Next One!!!
                  I dont see why i would have to do that theres connection to put speaker in the rear wich mean theres wires behind the hu that just not connected?
