5 channel or 4 channel + mono
    So I was curious as to what you guys thought would be better.
    I have an old school sony explode mobile ES 5 channel amp model xm-7557 rated at 4x100 and 280x1. I know newer explode stuff sucks but I remember these being pretty stout and like 700 bucks in like 2001.
    My question is is there any advantage to using separate amps for 4 channel and subs?
    The 5 channel has high current/high voltage select and has crossover's for each input individually.
    Also it has two input's for power and ground do I need to use both?
    TIA
    you would be running each amp at a higher wattage if you do them separately depending on amp/sub ohm impedance for example if your running a 2 channel amp maxed at 200wts and two subs they are running at ~100 wts each if you bridge one sub to that amp you get full power to the one sub.
    He's disappointed in my bulge... it doesn't even come close to being as impressive as his.
    1990 Accord EX
    1996 Civic hatch *gone*
    1994 Integra
      I would do a 4 channel and a mono amp or even a 2 channel for the fronts and just a mono for the subs. You dont really need to amp the rears.
        I HATE Sony Xplod stuff, BUT, the Mobile ES is actually good stuff. I'd run the 5 channel amp, you already have it, and you won't have to figure out another remote wire, ground, distribution block... and I'd amp your door and rear speakers, then add a sub and call it a day
          Yeah I can't think of why I would only amp the door speakers and not the rear.
          I'm only going to be running 1 sub. I have an old school rockford fosgate hx2 12"
          My thought was to only have one set of wiring, just wasn't sure if I would lose anything using one amp but I guess it's just built like that. Plus I guess stuff was made good back then. I wouldn't use sony car audio now to save my a**
            i think i kno witch am ur talkin about. when i 1st seen it i didnt even kno sony made something like that. older stuff is always better than the newer stuff. id keep that amp and make a built to spec box. if i ever came across an amp like that i would definitely buy it. if your not looking for somethin 2 loud this is the amp 2 go with
              oh then yeah for car speakers you can do all of them from one amp
              1990 Accord EX
              1994 Integra
                Here is the link from the amp it was from 2001
                http://www.crutchfield.com/S-PiYM6JE...S-XM-7557.html
                As far as I know it was $800 brand new and worth every penny. I picked it up on craigslist for $50 fully expecting it not to work but it's been great.
                There is also a pic in my beginner ride's post http://www.cb7tuner.com/vbb/showthread.php?t=161503
                  50 bucks dayms thats a coo price
                    go 4 channel and just run rear speakers to your stock deck and subs to the other channel that what i did and i love it
                    On To The Next One!!!
