Alarm Install
    Alarm Install
    I have just purchased an alarm and thinking of doing the install myself. i'm very functional with car electronics but seeking feed back from those that have done these before.
    take the dash of and hide the brain...also take your time, plan a couple of days ahead because if this your first install it will take you a while
    good luck!
    A & A Auto Service
    Pro-Spec
    TorontoJDM
    "Driven daily, or not at all"
      what brand is the alarm? do u have the schematics for ur car? are u installing n e extra components such as window modules etc?
        It's only a couple of wires...I think like 13 or 14. It's not hard at all.
        YouTube Clicky!!
          Prestige
            It's not that hard, you need a multimeter, the wiring diagram for your ride, a limber back and a few hours. My first one took me about three, but it also tapped into the doors, and I installed hood and trunk triggers. The instructions with the alarm should explain to you how to de-sheath and connect the wires without cutting them in half. Take your time and do a good job.
              dude its easy, dont let all the wires discourage you ive never done one and i wired my cb with smokeaccord then i did my brother's ef civic by myself with no problem, all ou need is this
              90-93 cb7 diagram
              and tools:
              electrical tape
              butt connectors (optional)
              zip ties(optional but its good to tie everything together and hide it)
              wire stripper
              wire cutters
              Originally posted by Uncle Willey
              When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
                it 0nly t00k us what half h0ur.
                my new turbo build
                  yep
                    Check out www.posi-products.com They have an amazing product called a posi-tap. It taps into hot wires without cutting them or removing the insulator. It installs easy and can be removed easy. Check it out. I havnt used em but if I get an alarm for my car Im going to buy these.
                    PSN
                    Vash744
                    MRT 1992 EX Coupe "The Jerk"
                    2009 Subaru Impreza 2.5i Premium Hatchback
                    2008 Honda Fit Sport (Totaled out - Death by fallen tree)
                    1993 CB7 Sedan LX (Totaled out)
                    1991 CB7 Sedan EX (Dead and Junked)
                      those are pretty good, my old alarm was put on with those or somethihg simialar
                        yeah it was......there nice and easy t0 put in but crazy t0 take 0ff.
                        my new turbo build
                          They R Simple To Install Just Time Consuming...now If U R Savy With Ur Cars Electronics It's Be A Walk In The Park...the Instruction Booklet Always Tells U Wire Wire Goes Where And Also How To Program Any Extra Features Once It's Installed...if U Need Any Extra Help Just Pm Me And I'll See How To Help U...
                          And Yes If Ur Like Me That I Like Eerything Nice And Organized Under My Dash The Try To Get Butt Connectors And Instead On Black Tape Try To Use Heat Shrink Tubing It Looks Soooooo Much Cleaner...hope This Helps...good Luck
                          God First, Family Second, and CB's for fun Third...
