I have 500 watts @ 4ohms to play with for my sub. I would like to run a single 12. Someone steer me in the right direction. Damn this makes me feel noobish, Thanks in advance
best 500w @ 4 ohm sub?
Originally posted by Ensjesse View PostKicker Solo Baric L5 12inch.
Jesse
memphis m3... square subs are pooh!!! whats your price range?Members Ride sold...
Originally posted by loud92CB7 View Postmemphis m3... square subs are pooh!!! whats your price range?
My partner got two of the subs that's the model below the m3 class...those subs like lots of power.
Originally posted by sonikaccord View Postx2 on budget.
My partner got two of the subs that's the model below the m3 class...those subs like lots of power.Members Ride sold...
hope the box is built not bought.... or else u wont see what that sub is capable of.Members Ride sold...
Well, kicker is out of the question from what i have read on other forums. Im hearing that there stuff gets loud, but its mad sloppy. I need decent sq as well as a little spl. I understand that you cant really have both unless you wanna blow $450 on like an id max or something comparable. What do you guys think about me getting an IDQ12v3, and putting it in a 1.8-2.0 cube box (slot port) tuned to 30~35 hz. My budget is around $250 for the sub, has to be either single 4 ohm or twin 2 ohm I have 500watts rms from a mb quart amp to screw with for my substge. The type r 12 is alot cheaper than the idq, but will it sound good? Also, I need the sub to match my front stage, a pair of Id 6.5" components that will be fed 100 watts rms.Last edited by richie92ex; 03-16-2010, 06:44 AM.
Originally posted by richie92ex View PostWell, kicker is out of the question from what i have read on other forums. Im hearing that there stuff gets loud, but its mad sloppy. I need decent sq as well as a little spl. I understand that you cant really have both unless you wanna blow $450 on like an id max or something comparable. What do you guys think about me getting an IDQ12v3, and putting it in a 1.8-2.0 cube box (slot port) tuned to 30~35 hz. My budget is around $250 for the sub, has to be either single 4 ohm or twin 2 ohm I have 500watts rms from a mb quart amp to screw with for my substge. The type r 12 is alot cheaper than the idq, but will it sound good? Also, I need the sub to match my front stage, a pair of Id 6.5" components that will be fed 100 watts rms.
the memphis subs you can order them in that config and wit that power u will be very please if everything is set right. its a very musical sub! Hertz hi energy is a another sub i have gotten a bit of time with and my wife loves hers. that shit is stupid loud.Members Ride sold...
