Anyone using an LED distribution block?
    I may get on for my system but I need on that has at least a 4ga input and 3x 4ga outputs. I have seen one from Stinger that has 2x 4ga inputs and 4x 4ga/8ga outputs. Any suggestions? I would also like to have an LED display if possible. I am trying to get max power and to run 4ga to 3 amp total. So I will need 2x distributions blocks (Power/ground)
    huh?
    Members Ride sold...
      Are you looking at something similar to this?
      http://images.google.com/imgres?imgu...GoPmtgPX8KSxDQ
      They're not really necessary, they just let you monitor the voltage going to your power wire.
      When wiring up your amplifiers, I've read it's best to ground them to the same spot and to keep your ground wires as short as possible. Usually 18 inches is about the perfect length, shorter if you can get it
        Yeah, I know about the ground wires and stuff, past all that. I am not trying to be rude and do appreciate the help. I am just looking for and thought someone may point me in the direction of a led distribution block that has 1x 4ga in and 3x 4ga out for a multi amp setup in the future
          I used to have a distribution block that displayed the voltage.
          Imo It was a waste of time (and the extra money) because it was in the trunk, so you never really see it anyway.
          If you want to know battery voltage, you'd be better to get a separate gauge you can mount somewhere on the dash.
          Btw max sig size is 500x300 pixels as stated in the stickies.
          My 5.7 LS1 Holden Ute
            u wont find a 4ga in with x3 4ga out. it will be 0ga in and 4ga out. knukoncepts makes some nice stuff for a decent price last i checked.
