okay im planning to get a alarm with a auto start soon but im wondering if its a good idea to have a auto start with a manual car...because sometimes i when the car is in first gear wouldnt the car stall??
auto start on manual
The clutch can be bypassed to use remote start to start a car with a manual transmission. However, if the car is left in gear, it will still start and can take off unoccupied.Originally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
Originally posted by sonikaccord View PostYes it's possible. You have to get a good remote start system that makes sure you leave the car in gear before you leave.
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
Originally posted by Ander View PostWhat? lol. Why would you leave it in gear?
There is a way to install a neutral safety switch so the alarm wont let it start unless it's in neutral. I'll try to find the site where I saw how to do it. It basically works by a wire grounding out with the shifter in any gear, then when in neutral the wire doesn't touch anything.Originally posted by chessboxerWe know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
Ive got one. I was wondering the same thing, because I know that there is nothing telling the ECU that the car is in neutral. There is no electrical connection for any gear (besides reverse I guess).
The way mine is installed is:
When you park (car still running) you have 30 sec. after you pull the handbrake. You push the start button on the remote. Wait for the 3 flashes from the parking lights, then pull the keys from the ignition. Open the door, exit the vehicle, close the door. The car is still running. I hit the start button (or the lock button) and the car shuts off. It is now armed.
If I open one of the doors before starting the car with the remote, then the system trips and the remote start is no longer armed.
I think the theory is that if you leave the car while it is running, there is no way it can be left in gear. And if you open a door while it is not running and armed, you could potentially put it in gear.
So once I arm my start, I dont go into the car without starting it remotely, otherwise the system trips and unarms itself.
Does that make sense? Like I said, its goofy, but I don't know any other fail-safe way.
When I remote start it, I also unlock the doors. Once I get in, if i put the handbrake down or touch the clutch before putting the keys in, it stalls. This also keeps my from habitually pushing the clutch in and turning the key to "start" which would destroy my starter fairly quickly on an already running car.
Hope that helps
