i need help with the original audio wires.....pla help me
    i donr know wat happen but i have a 92 accord ex sedan 5speed...
    the car has the original wires i dont know have to many diferent colors they dont match with new wires i need help somobody dat know about audio wires plz i need to do it asap thanks
    "Números para las cuentas,palabras para las damas,la mano para los amigos y las balas para los enemigos"
    "Numbers for the accounts, words for the ladies, hand for friends and bullets for the enemies!
    What I did was get all the color that match first..
    There should be at least two or three that you don't need.
    btw, did you buy the wire kit from store?
      are you talking about the harness where the radio is?
        I'm not entirely sure what you're asking... but I've rewired my stereo several times (swapping in and out HUs) so here are the colors on the factory side from my memory:
        A. +12V ignition : yellow w/red stripe
        B. +12V battery: white w/yellow stripe (sometimes a blue stripe)
        C. Power antenna: brown w/white stripe
        D. Ground: black
        E. Right rear speaker (+): red w/yellow stripe
        F. Right rear speaker (-): brown w/white stripe
        G. Left rear speaker (+): blue w/yellow stripe
        H. Left rear speaker (-): gray w/white stripe
        I. Right front speaker (+): red w/green stripe
        J. Right front speaker (-): brown w/black stripe
        K. Left front speaker (+): blue w/green stripe
        L. Left front speaker (-): gray w/black stripe
        The aftermarket stereo harnesses connectors can vary in color sometimes, but not their placement! So if you bought an adaptor harness, this is how it should be wired up with using the above color guide:
        I hope this helps you out... if not I hope it helps someone out.
        Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
          Can you please tell us, in far more detail, what happened, or what you are trying to do, or what is going on? I don't understand what you are saying here.
          Something happened? What happened? Even if you don't understand the cause, can you describe for us what occurred to begin with?
          What wires are you talking about? Speaker wires in the doors? Electrical wires for an amplifier? Head unit wires in the dash?
          A lot of us on here would be happy to help you, we just need to know what you actually need help with.
            D. Ground: black
            actually this is some awesome info im going to bookmark this..honestly i just look at the colors and matchnit up and if it is the same color as another there is usually a black stripe that set it apart...always works for me and EVERYTUIME im surprised i actually did it right. I hate wiring
              LOL, I love wiring... I probably would have became an electrician if I weren't doing what I am doing now.
                thanks man big help...took me 20 mins
                FreshNoz
